ARCHIVE Owl Expedition Media Mount (1 Viewer)
I'm new to this forum and joined because of Rmathorn15's tablet mount for the LX470. I own a 2003 LX470 and would like to purchase. Might want some custom design or wiring advise as I have both iPhone and Android phones and wonder about phone integration with the tablet (could either get the new Google Slate or an iPad mini).
Welcome!
I personally run an Android tablet because the Tasker app allows you to do cool things like have the screen time out automatically when not charging (key off) and never time out when charging (key on). Also, you can use cheap Bluetooth obd2 adapters with the torque app. I'm not sure if anyone has made a good obd2 Bluetooth app for iOS.
Was just checking out the new slate. Looks pretty sweet!
I thought some might be interested in some photos of an installation on a 2001 LX470 with Nav, so here goes:
Putting the plate into the cassette deck (I include this because although the outside looks very different from RT's original installation, the interior looks identical and it does work):
full
How it looks from below with the trim panel on:
full
Detail of the Smallrig joint--amazingly it looks like the plate and the smallrig joint were made for each other!
full
Alas, it did require drilling another hole to fit the location of the 1/4" coarse thread screw mount of the Smallrig:
full
But you can't really even see the original hole. Nice, right?!
full
Here's how it looks with the phone and tablet mounts on. Note that there really is little interference with the existing controls.
full
Now that it is basically set up, it is time to do some wiring. I cut some vent slots to make a hole big enough for four cables (3 USB and one audio). The edges were pretty sharp and I did not happen to have a rubber grommet so I wrapped some camel leather (because I happened to have it) around it and secured on both sides. My only concern is possible overheating, but the front plate will be open and the motors are removed, so I'm just going to hope for the best.
full
So this is what it looks like with a phone and tablet installed (before securing the cables, which I will do later):
full
As previously mentioned, I will shorten the vertical bar holding the phone most likely, but I will wait until I have it in the truck and can decide on final location. Now I've got to install the BT45-TOY and CAS-LEX cable, plus a couple of extra USB motorcycle USB power units so I can power the phone, possibly a dashcam to be mounted behind the phone, and have two more USB power points mounted in the face of the ashtray.
BTW, I got some 90 degree bend USB cables for the inexpensive Amazon Fire HD table (it was only 65 bucks or something) so that the cables were a little neater. Pretty much same price as regular cables, but you have to hunt a bit on Amazon to find the right orientation on the USB power cable.
One other thing; RT had mentioned that he was not sure if it was going to fit (and in fact I had to drill another hole, which was fine), but in case anyone wants to know, the back side of the Smallrig joint ended up about .45 inches away from the plastic trim, which seems to be enough.
full
Oh, I ought to mention that I left one of the USB cables inside the cassette deck so that I can pull it out later for the dashcam power. When I looked at the situation I realized that it was not going to be easy to fish around in there later to get that cable, and also that I did not want the bare metal end of the cable to be floating around in there. So I took a large bit of red heatshrink and coverd up the end of the USB cable, then I took a smaller black bit of heatshrink and covered the end of the red. Then I pulled that out of the front of the cassette deck and into the original hole of the Owl Expedition plate so that I could just reach it there and grab it. Because it is matte black and everything around it is black, you wouldn't notice it unless you knew it was there. So the original hole ended up having a function anyways.
full
The red paint that you see on the screws is actually red nail polish. I used that instead of locktite because I didn't seem to have any of that on hand. Hopefully it will do about the same job. I used it on the 1/4" coarse mounting screw and between the Smallrig joint and the plate as well, to hopefully reduce the possibility it will loosen up with vibration. At least that screw is easily accessible with the radio in-place.[/QUOTE
Your setup looks awesome! I'm thinking of copying, my o vm ly questions t.f ion is how it handles offroad with vibration? Is it solid?
I was as tester for the Lexus GX470. Works great. Strong and keep my tablet and phone close by and very visible.
I've tentatively settled on this layout:
Mr. Young. Your layout was genius. I copied your exact set up... why mess with perfection! I'm super pumped with the layout and the quality of the Owl Mount. You better believe I installed the Owl sticker on the dash for everyone to see! If you haven't done this accessory you are missing out. Get yourself the owl mount now! Fyi... all OEM buttons and dials are accessible with this set up! No affiliation with Owl, I'm just a satisfied customer.
Cheers fellow mudders.
LOL! Imitation may be the sincerest form of flattery, but I liked your compliement too. Glad it worked well for you! My setup continues to please every day!
@Ramathorn15 - looks like your sold out of the mounts on your site- any idea when you'll have more in stock?
I was wondering why the last one I had was taking so long to sell.
It's posted now. Be quick!
Also, if you're interested in one of these, post here. They have died down enough to not really justify me reordering more.
Thanks!
Thanks!
I’m want to purchase one as well, do you have any left?
