The easiest way to check a viscous fan is to take a piece of cardboard or something that will not damage the fan and try to stop the fan while it is running at operating temp. If you can stop it without too much effort the clutch is bad.
I'm glad I checked this thread because I am having the same problem on my 88 22-RE. I have recently done (all new) radiator, water pump, thermostat, hoses, timing cover, and fan clutch. We are having a wave of 95*+ days and as I drive around it approaches the red line but doesn't actually get into it. I haven't broke out the thermometer yet but it's bubbling into the overflow when I stop. It isn't using any coolant and I don't see anything in the oil or coolant. I know I need to readjust the valves and maybe tweak the timing and TPS a bit (TPS was bad and I couldn't set the timing and I'm not sure I got the settings just right). Does anyone think that those things may cause a overheating situation? My 87 gets hot if I'm under load for a long time but it is very linear and if I let off it cools down. This one just stays hot till I shut it off. Any ideas?
