Here's some information on my output shaft bearing project.
I decided to replace the output shaft bearing and seal as part of a larger project to upgrade the differential to a 4-pinion Harrop eLocker with new Nitro gear bearings. Almost everything in the front differential is being replaced with this project.
This part is the reason for replacing the output shaft bearing and seal.
While the original output bearings felt reasonably ok at 235,000 miles, I could feel a considerable difference with the new bearings. The shaft now feels as smooth as glass while turning in the bearing. I think it may feel like a new truck when I'm finished.
Parts
90311-47013 Axle Seal
90363-43001 Outer Bearing
Start by taking a good picture of the outer seal.
Use the picture as a reference to determine depth for where the seal should be positioned on the lip during installation.
I used my well worn seal puller to remove the old seal. The wide lip on the seal and shaft tube made it require a few rough pulls to remove the seal.
It still works. Though a professional seal puller would have been easier.
Once the seal has been removed, you can see the bearing and two c-clips that hold the bearing in the shaft tube.
My trusty angle needle nose pliers worked well to remove the outer c-clip.
Continued on the next page.
Parts
