Hey guys,
Just installed a "new" 3B into my BJ this weekend and I have found two problems that I hope you guys can shed some light on...
Waterpump - it leaks like a siv (seive??). I put a new gasket on and cleaned up both surfaces really well. The new gasket is from the dealer however the waterpump is off my other 3B of the same year truck. Am I missing something there?
Oil Pressure - I have none. Full of oil, filled the filter before I put it on (its a Fram PH8A). I pull the pressure senor off and nothing spits out when I crank the engine over. This engine is out of my wrecked 60. I had to replace the front timing gear housing (not the cover, the whole thing). So to do that I had to remove the oil scavenger lines from the oil pan as well as the cam/lifters/rockers came out. This engine was running fine before the truck was smacked. Any ideas for this one?
I followed the procedures by the FSM. I checked the engine out and it seemed to be alright for the switch. If the block was cracked somewhere, would I get a tiny bit of pressure?
Thanks guys
Geoff
Thanks guys
Geoff
