Hi All
HZJ73 with 520 KKM
Have low pressure readings cold and hot, on the factory gauge.
Would like to perform oil pressure check as recommended by manufacturer: pulling the sender unit and putting a mechanical gauge on a flex line.
Does anyone know what is the tread type and size for the OEM sending unit on the 1HZ?
Also,
@sodafeld1 , You mentioned installing an oil bypass filter, can you elaborate as for the reasons/advantages and installation details?
Or refer to a specific thread where this info is available?
Thank you
I got an ultra oil bypass filter for my 2h on ebay au. It bypasses the oil return line before the oem filter with a sandwich adapter. The ultra filter is like a toilet roll which helps filter the oil much more than the oem filter. My engine oil is much cleaner, I still change at 5000km though. I also use the bypass return oil line to remove 500ml of old oil and replace with fresh through the filler hole each tank of fuel. The sandwich has two extra holes of 1/8npt and 1/8bsp for extra gauge senders if you desire, so has more than one function.
If you search 'oil bypass filter rave!' you should find it.
I like it, I like clean oil. Been using it for close to 100000km. The rubber seal for the sandwich can be replaced with a seal from a standard size oem filter if need be. Mind you, there are folks who get 6-800000km from a 2h without the bypass filter, so probably don't really need one.
It all started for me with high oil pressure paranoia in the 2h with some folks getting stuck relief valves, never happened to me as I addressed the valve, don't want it to happen. If I get aroundtoit, I would make a bridge on the internal of the rocker cover for the filtered return oil to drip on all of the rockers rather than just two of them, but they all seem happy enough.
I have a mechanical gauge on the sandwich and an autometer digital going to the dash, they calibrate which is excellent for monitoring oil pressure. Didn't want a mechanical gauge on dash for the risk of the line leaking or bursting and gushing hot oil potentially inside the car, engine bay is better for that, if at all.
Happy I did it awhile ago as the good brand gauges like marshall and autometer have nearly tripled in price since covid. I don't take much notice of the oem gauge much anymore, I think the oem was 1/8npt from memory on the 2h, but hopefully someone shall speak up there if I am wrong. Don't know the 1hz much, besides it is good. Very happy with my aftermarket oil and temp gauges, the oem gauges do not tell you much.
I can highly recommend the aussie watch dog engine guard though. It gives excellent accurate head temp, also good to know exactly when your engine is warmed to running temp.. Poos all over oem gauge. You can hear the viscous fan kick in, or watch your temp drop when your thermostat opens like digital clock work with it.
