So I left my office this evening after my '84 FJ60 sat in the lot all day and about 3 minutes in to a 5 minute drive, I noticed the oil pressure needle was essentially pinned at the top. I arrived at my destination and the truck sat for about an hour and I came back out and cranked it to find the gauge now down below the L (low), but not buried like it is when off. Temp gauge was just above C since I hadn't gone very far also.
I just had an oil change last week performed by a very good FJ60 mech. I am not much of a wrench, but I checked that the wire for the oil sending unit is connected as I saw in other threads (to the pin in the middle). Oil level is fine as well and no leaks or anything to be found.
Under the oil filler cap, how much oil should I see? It looks well lubed, but I don't actually see a pool of oil in there.
Do you think this is a sender/gauge issue and its actually safe to drive. At the moment I'm stranded trying to make sure I won't kill my smooth running 2F if I run it.
