pbgbottle
Forum Lifer
Canada may have the oil gauge ,what are you after the gauge or the sender? .
the fuel ,water,and amp gauges are both shared by the FJ and BJ ,but for some reason the oil sender and gauge are not shared
my rig was once a 78 BJ40 .i purchased it without the drivetrain ,i put a chevy in it .and i am still using the diesel gauges i did remove what looked like a resistor from the back of the gauge cluster.,
funny thing is i never realised the oil gauge was differerent ,i am currently getting readings on my BJ oil gauge. using a FJ40 sender.
surprisingly .the gauge seems to read accurate acording to the diagram in the
owners manual . there may be not much difference between the two gauges who knows , mine was a 24volt also
so if you are getting no readings and have tested it with a known to be working sender. the the gauge is probably garbage . i might be able to ask around if anybody has a 24volt gauge kicking around.
Jake
Jake
