Now that you mention it I remember reading that somewhere too. Think it was difference between years (60/62).Mine is 12mm. I’ve read that replacement oil pans use a smaller diameter drain plug than the original.
So that statement right there is saying you purchased a new oil pan. The new updated pan is different than the old pan.... And it requires a different gasket than the old pan.
It also has a smaller drain hole than the original pan, requiring the smaller drain bolt and gasket.
New updated oil pan: 12101-61013
Gasket for pan above: 12151-61011
Drain plug for above: 90341-12012
Drain Plug gasket for plug above: 90430-12028
Old (wrong) original oil pan gasket: 12151-61010
(in a pinch 12151-61010 can be used successfully if it's mounted perfectly with a little Toyota FIPG. It will crush down and seal)
