Argghhhh....
Ok, so it was time to replace the leaking oil pan on my 3B (someone had previously tried to fix the leak with epoxy to no avail). Obtained a very good used oil pan from exmodlad (thanks!), cleaned it all up, POR15'd the exterior. Removed the old pan, kept the bolts and brushed them off. Cleaned the mating surfaces perfectly, applied the proper Toyota black sealant, then hurried to put it on and apply the bolts before the sealant hardened (I gather there's a 15 minute window).
So here I am, crawled under the truck, arms greasy to the biceps, trying my best to put in and snug up all the bolts in sequence (starting from the center and working my way out). Hands slippery on the ratchet handle, eyes filling with dirt, arms getting tired. All of the bolts were going in nicely and tightening up nicely too (very snug). All of a sudden, SNAP :whoops:, one of the bolt heads breaks off as I was reaching the tightened setting of the others. Damn! Keep going, then sure enough another one snaps off at the opposite end of the pan. So now I've got 2 broken bolts, with everything else well snug, sealant oozing out nicely on the side.
So the question is (dare I ask with trepidation...): will the pan have a likelihood of sealing with those 2 broken bolts (ie. will the bolts on either side provide enough clamping force to allow the sealant to fill the gap?? OR: will I need to consider taking the whole thing off, drilling out the broken bolts, buy new bolts (in retrospect, what I SHOULD have done in the first place!), clean the pan and sealing surface on the engine, and go at it again...?
I attach pictures of the 2 broken bolts, which are at opposite corners of the pan. Thanks for the advice...
p.s. a passing thought: would applying JBweld on each hole of the broken bolt head be a solution to prevent having to do this all over, and prevent a possible leak there? (one of the broken bolts would be a bear to drill out, given other things in the way underneath)...
