oil pan for F135 motor
red66toy
Supporting Vendor
Seattle, WA
Anyone know if a 2F oil pan will fit on a F135 motor? Thanks
I can't remember, I thought some trimming of a baffle was needed to clear the sump????
I have a new 2f pan that I might use on my f135 rebuild. My original pan is fine but has a small dent in one front section. If the 2f pan doesn’t require trimming when using the f135 oil pump them I’m using it.
This is probably common knowledge to some but I confirmed the current 2f oil pan (12101-61013) works with the F135 if using the factory oil pump and filter pickup. This is the newest pan and is supposedly backward compatible. It also uses a similar but slightly different gasket which is 12151-61011.
I used a Wi-Fi camera and did my best to verify the baffles didn’t interfere with the dipstick, oil pump or filter pickup. Nothing touches but some parts are close!
1909626
1909627
1909628
1909629
1909630
Awesome! Thanks for the test and thorough verification! :D
