Oil Leaks
Discussion in '60-Series Wagons' started by jreed32152, Feb 26, 2007.
  1. jreed32152
    jreed32152
    212
    Apr 27, 2005
    Boise, ID
    I got under my truck last night to do an oil change and it looked like my transmission was leaking as well as one side of my oil pan. Do you concur? What do I need to do?
    Cant post pics.... problems... pics soon to come
  2. phoenixrider
    phoenixrider
    359
    Feb 21, 2006
    Well, my 60 had a big oil leak, and it turned out to be the fuel pump. Wasn't easy to track down, either
  3. mtb_rider
    mtb_rider
    881
    2
    Feb 17, 2007
    Wilsonville, OR
    Well, hard to concur without seeing, and also don't know if you have a 60 with the H55 manual, or a 62 with the auto. If you have the auto, I'm sure you know this, but ATF is red (or should be, unless it hasn't been changed in 15 years), so that would be a tell tale if the trans was leaking. I am not sure what the H55 runs for lube (I have a 62 with the auto), so I couldn't tell you what color it should be. I can tell you that I have an oil leak on my truck as well, but I'm pretty sure it is the rear main, and it isn't bad enough to try and fix, because of the severity of replacing a rear main, and a very minor valve cover leak that I will fix sometime in the not too distant future.
  4. jreed32152
    jreed32152
    212
    Apr 27, 2005
    Boise, ID
    Pics
    Heres the pics
    Any ideas. The oil on the trans. looks like engine oil (not red).
  5. jreed32152
    jreed32152
    212
    Apr 27, 2005
    Boise, ID
    Mines an 88 62 with auto
  6. roscoFJ73
    roscoFJ73
    15,286
    Media:
    3
    Albums:
    1
    1,582
    Jul 22, 2003
    Perth Western Australia
    Clean it up best you can,especially around the seals and gaskets. Then go for drive ,get it nice and warm and get under there with a flashlight and look for oil seepage.
    From the pics I would say it the rear main seal. However a valve cover or oil pan can also do that and occasionally the rear camshaft seal.
    When looking for the leak,remove the cover from the bellhousing and have a look up behind the flywheel as best as possible.
