Oil In Air Filter
Discussion in '60-Series Wagons' started by kptfj60, Feb 25, 2007.
  1. kptfj60
    kptfj60
    137
    May 30, 2006
    Kittery Point, Maine
    Hey Guys-
    I just finished putting a new smog pump in my 60 today and as I had everything apart I noticed an inordinate amount of oil/oil residue in the back of the air filter where it connects to the valve cover. Any ideas what this could be? I've always know a little to be normal but this seems like a bit more than I've ever seen. Oh yes, and the smog pump went amazingly well. Thanks
  2. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    Yeah..You need to check your PCV valve and make sure you have a good vacuum on it. Pull the vacuum hose off the top of the hose and make sure you have a vacuum. I would also change the PCV valve if it has been a couple of years. They are cheap from the dealer. Sounds like your engine can't breath properly. Did you have any oil in the lines connecting to the back of the smog pump?
  3. Texx
    Texx
    2,895
    17
    Feb 27, 2002
    pretty typical for an engine with burnt valves as well...lots of blowby.
  4. FJ60Cam
    FJ60Cam SILVER Star
    8,682
    10,100
    Nov 1, 2004
    Memphis, TN
    I thought blowby was a symptom of worn out rings... ?
    Mine would turn an air filter black with oil within a week before the rebuild.
  5. kptfj60
    kptfj60
    137
    May 30, 2006
    Thanks for the input guys. My first thought was blowby, which I also thought was a symptom of worn rings. Must be getting time to make some decisions.
