Is it possible to change the oil in a 200 series without using ramps or a lift?
Thanks,
Kevin
Thanks,
Kevin
Thanks,
Kevin
The entire skid plate must be removed to access the filter and drain plug.
And where did you get that bit of misinformation?
To get to the oil filter on my 200, I have to remove the left hand front fender splash shield sub-assembly - that's 3 bolts - and then the No. 1 engine under cover sub-assembly (that's the TIS terminology for the left half of the skid plate) - that's another 5 bolts. My math (and trust me, I'm very good at math) tells me that's 8 bolts to remove just half the skid plate - definitely not "only 3 bolts holding on the entire skid plate."
To get to the oil drain plug, it's another 2 bolts to remove the No. 2 engine under cover seal.
Honestly, I have yet to find any "under engineering" anywhere in my 200![]()
Well to be fair, the 200 has 3 bolts, only 1 more than a 100.![]()
3 bolts for the entire skid? Wow! No, the 100's full skid has 4 or 6. The little panel in the skid only has two. 3 is not too bad.
I ended up using my ramps. I was able to replace some broken bolts inthe skid plate. But, I did see evidence of a leaky water pump, there was plenty on pinkish crust. It there any threads around here detailing how to replace the water pump?
