Lol ummmm. I’ll just do to it what I’m doing to everything else. Take a sledge hammer to it.
Stretch the frontOk. Last question. Lol
My passenger side tire is rubbing the exhaust when I turn to the right all the way. Did y’all cut and move the exhaust or just lift the front higher?
Stretch the front
Stretch the front
Do you know what it might be called? I checked through their parts and didn’t see anything.I think redline land cruisers has a piece you weld onto the frame side control arm mount that pushes the front axle forward an inch. That might be preferable to hammering your exhaust pipe closed.
I have front and rear DC shafts that are extended already.With moving the axle forward you’ll need to extend the front driveshaft.
Lmao. Nooooo. Not going down that road.Just 3-link it already![]()
Awesome. Thanks
But if you move the axle forward further away from the TC... I would at least measure again to make sure. Also, you could have a custom DS spacer made for it and use longer bolts at the flange.I have front and rear DC shafts that are extended already.
Who makes the spacer?But if you move the axle forward further away from the TC... I would at least measure again to make sure. Also, you could have a custom DS spacer made for it and use longer bolts at the flange.
From VCCruzr's flop/chop build.
Follow the link to the threadWho makes the spacer?
Ya sorry. Missed the link when I was driving. Thank you.Follow the link to the thread![]()
