I made my own fluid heat riser. In the fog on a long grade it would ice up the carb before I did the heat riser.
On V-8's it's not an issue as the intake is over the valley pan and helps preheat.
* - TriMeki header details here: TriMeki 2F/F Stainless Steel Header & Exhaust System - https://forum.ih8mud.com/threads/trimeki-2f-f-stainless-steel-header-exhaust-system.1337067/I’ve considered (as part of @Fe3) casting (and productizing) a matching(*) manifold for the 2F but with the carb plate to fit a 2bbl Sniper, so you don’t need the machined adapter to the manifold.
Good 2F manifolds are getting more and more rare.
The original carbs and manifolds were smog devices, with the heat from the exhaust cooking the intake so they could atomize fuel and work with so-so porting.
The “heat” isn’t for emissions/carb, it’s to improve cold weather drivability. It’s so the atomized fuel in the intake doesn’t hit the cold metal of the intake and “drop out” (condense), leading to an instant “lean” condition, requiring you to “give it some gas” just to keep the engine running.
(*) it would be designed and machined to fit well with the TriMeki 2F header
Hi,* - TriMeki header details here: TriMeki 2F/F Stainless Steel Header & Exhaust System - https://forum.ih8mud.com/threads/trimeki-2f-f-stainless-steel-header-exhaust-system.1337067/
I imagine it would be possible to incorporate a coolant loop under the floor of the intake to deal w/ cold weather driveability issues.
Might be a good time to upgrade the exhaust valves to small block Chevy stainless valves. You'll need to ream out the guides a little, and grind the seats to match the valves.
Agree, but high quality stainless and pro-level TIG welding —> Made in USA will always cost more than imported things.Hi,
the TriMeki header on 2f would of course be very cool,but unfortunately it is quite expensive...![]()
Agree x2. This is a product that will easily last for our lifetimes, and then be there for whoever inherits our Cruisers.Agree, but high quality stainless and pro-level TIG welding —> Made in USA will always cost more than imported things.
Hi,Agree, but high quality stainless and pro-level TIG welding —> Made in USA will always cost more than imported things.
Maybe you are really bad at math....Actually part freeway at then 55mph for about 50 miles out, then about 70 miles idling along in second gear road hunting varmints, then back to the same gas pump I filled up at on the way out. I did this for many years and always got 25mpg for the trip.
