Elijah Joined Jul 22, 2005 Threads 74 Messages 1,062 Location slc area Mar 16, 2006 #1 What number do I multiply the indicated speed by when running 315's. Could've sworn I just read it somewhere. Couldn't find it in a search. Thanks.
nakman addict. Supporting Vendor Joined Jul 30, 2003 Threads 72 Messages 2,932 Location Broomfield, Colorado Website www.gamiviti.com Mar 16, 2006 #3 Check out the calculators here: http://pitbulltires.com/calculate.php If you're still running the stock t-case gear, I think you'd be about 12% high? So speedo*1.12=actual.. someone will no doubt correct me if I'm wrong.
TroutRunner Joined Oct 26, 2005 Threads 57 Messages 1,161 Location Farmington, NM Mar 16, 2006 #4 Assuming you have stock gears and no speedo correction. Going to 315's will be about 11-12 percent change. Easy way to calculate what you are going is to move the decimal one space to the left and add it to your speed. Thsi is actually 10% difference. 60.0 on the speedo is 6 (move the decimal to the left one space) + 60 = 66 mph 25.0 on the speedo is 2.5+25=27.5 mph. Only a 10% fix but....GEEZ....How much math can you do while driving anyway. TR
Elijah Joined Jul 22, 2005 Threads 74 Messages 1,062 Location slc area Mar 17, 2006 Thread starter #5 I was thinking it was 12 percent, wasn't sure. It's stock gearing. Thanks.
ginericLC Wagon Wheeler! Joined Jan 29, 2003 Threads 360 Messages 8,339 Location MH, IDaho Mar 17, 2006 #6 At 71mph indicated I'm doing 80mph. This is with Toyo MTs in the 315. When I had the 315 BFGs It was like 73mph that was 80mph. I'm running stock gears. At 20mph I'm at about 21mph. 45mph is 52 if I recall correctly.
landtank Supporting Vendor SILVER Star Joined Mar 27, 2003 Threads 383 Messages 21,139 Location Groveland MA Website landtankproducts.com Mar 17, 2006 #7 original tire 32" new tire 35" 35/32=1.09375 so a 9.375% change in speed. but those are rough numbers and the actual tire diameters are slightly off but you get the idea.
