Speedo repair
Ridgecrest Ca
Does anyone know of a place that will repair the trip odo on my 1996 FZJ80, all I can find is places that repair the electronic speedos
Are you talking about the odometer and/or trip meter?
Both are a part of the speedometer, which sources its input from an electronic sensor at the t-case.
I don't see why someone wouldn't repair the odometer and/or trip meter if they repair speedometers.
many times the little plastic linkage on the reset lever breaks, and makes the trip meter drive get separated from the gear on the trip meter. I've successfully and very carefully glued one together in the past, and I've also replaced a whole speedo/odo unit with a known good one and reset the mileage to match the vehicle it was being installed into.
The parts aren't available separate from the entire speedo head, but a good place should be able to scavenge a good one and use it in yours. Pretty much any toyota with a mechanical odometer/trip meter from the late 80s-late 90s will have the same parts.
