% of difference in speedo with 315's?
slc area
What number do I multiply the indicated speed by when running 315's. Could've sworn I just read it somewhere. Couldn't find it in a search. Thanks.
Assuming you have stock gears and no speedo correction.
Going to 315's will be about 11-12 percent change.
Easy way to calculate what you are going is to move the decimal one space to the left and add it to your speed. Thsi is actually 10% difference.
60.0 on the speedo is 6 (move the decimal to the left one space) + 60 = 66 mph
25.0 on the speedo is 2.5+25=27.5 mph.
Only a 10% fix but....GEEZ....How much math can you do while driving anyway.
TR
I was thinking it was 12 percent, wasn't sure. It's stock gearing. Thanks.
At 71mph indicated I'm doing 80mph. This is with Toyo MTs in the 315. When I had the 315 BFGs It was like 73mph that was 80mph. I'm running stock gears. At 20mph I'm at about 21mph. 45mph is 52 if I recall correctly.
