Where did you guys get your rivnuts for the sub tank mounting straps? Do you have any pics of the rivnut install and the holes that you drilled in the floor?
Thanks elmariachi. Do you happen to have any photos of the cargo floor after you put the rivnuts in?Just exploring options.
On a side note the rivnuts I used were slightly (Not by much at all) longer than the ones every one else seems to use. I had a hell of a time getting the Rivnuts to collapse in to place using the bolt/washer/nut/washer/nut method. I found it easier to use about 8 slightly oversized regular washers on a bolt and just torque it down. The rivnut collapsed in seconds.
Any idea on what size "everyone else is using"?
