A few of the above torque values are incorrect for the LandCruiser, and one important one missing.
The following is from the 2013 LandCruiser factory service manual. Other years will be similar.
Lower shock bolt/nut: 133
LCA pivot bolt: 207
UCA pivot bolt: 136
Sway bar link to LCA bolt: 100
Driver side KDSS arm to sway bar link bolt/nut: 103
Passenger side sway bar to sway bar link nut: 94
The following was correct, but to clarify
TRE to knuckle: 51
Upper ball joint to knuckle: 81
Lower ball joint to ball joint bridge: 123
Ball joint bridge to knuckle (2 per side): 221
Upper strut nut (4 per side): 33
Both ABS retention nuts: 9.6
As mentioned, LCA and UCA pivot bolts need to be torqued with vehicle at ride height, not with suspension dropped out. Typically this is the hardest part of the job for me, even with ramps. I just have trouble fitting myself under there and getting 207ft-lb worth of leverage on the torque wrench. A 4-post lift would make this a very easy step.
Not trying to sound stupid, but I don't understand. Do you mean it's not worth the effort to unbolt the lower bushings on the LCA?
Not stupid. I did a poor job of explaining.
Some people leave the LCA to frame bolt tight to preserve alignment. When you do this the bushing acts as a spring resisting the LCA being pushed down. This then requires a tremendous amount of force.
It is far easier to just loosen the bolts, let the arm swing down, install the strut. Swing it up, bolt everything together other than the upper and lower arm pivot bolts, set the truck at ride height, and torque those too.
