OEM Hand Throtle
robbie said:
I have had to make a couple for customers by cutting a piece of metal and welding it on, does not take much if you have a welder, The fine pictures will provide a great idea of what need to happen. I drilled a hole and used a hacksaw to cut the slot, then used small files to make the hole square of the right size for the cable attachement. all takes less then a hour. later robbie
My 94 Does Not have the mounting point. :mad:
Robbie how much to make me a bracket and I'll weld it on here? I still need some small parts from Slee, I could combine orders and save on shipping :)
Dan, the part number for the pedal at the local Toyota dealer is 78120-G.
The schematic on the computer screen included the hand throttle assembly and the bracket mounted to the firewall (and assorted screws, etc.) but did NOT show the backwards "L" bracket at the top of the pedal!
David
David
I want to say thanks for checking. I am afraid to gamble on a non returnable special order to try an fix my pedal.
Steven
David
78120-G is not actually a part number, that is a part-name-code that directs you to the text where the numbers are listed. The left-hand drive part numbers in the US catalog are 78120-60040 and 78120-60080. The 60040 fits Jan to Jun 90 and the 60080 is July 90-up.
D-
D-
But I was close ;) !
Just curious - does your catalog show the "L" bracket or just the top of the pedal.
David
93 (feb). does not have it. wish i had it. been looking for a picture of it. i can now make it and then weld it in place. soon i will be able to install the throttle kit (it is on back order). i hope it comes soon. it will make me happy.
05/93 Does not have "L" bracket at top of pedal... :crybaby:
12/94 does have it.
and the point of this all is ...?
that one can go take a walk alongside (or a leak) while the truck is crossing the outback all by itself...? :D
1. Raise the RPM's for jump starting a vehicle
2. Alternate Cruise Control (unsafe)
3. warm up the truck faster wile parked
4. becuse you can and it gets rid of a option blank
We used hand throttles on the vehicles in the fire department I used to be on for a couple of reasons - you can control the water pump driven off a PTO kind of setup, they can help with increased electrical loads like lots of incident lighting, and also you can increase RPMS for winching (the heavy rescue rig).
I suspect on the 80 it is used when winching so you don't kill your battery. Maybe?
Charlie
The hand throttle can be set to ncrease the RPM when it is parked. It's very useful for the increase electrical load, such as the winch and microwave, and also to boost the AC in extremely warm weather.
Yep. It doesn't show up on any of the fishe pics at the dealer, so it may be one of those non-US-don't-think-about-it parts. If I can't find it through the dealer (good discount) I'll get it from Christo.
So,
If you can't save a few pennies you will go to the guy who has gone to the effort of researching and importing them.
I can tell you that the number he imports is not the same one as the numbers that appear in the RHD (JDM/OZ) catalogs. None of the numbers appear in the US master.
