SOLD Ocean Springs, MS 1987 Toyota FJ60
Year
1987
  1. 60 Series
Ocean Springs, Mississippi 39564 United States
Mileage
168000
Color
Silver
Outside Link
https://www.facebook.com/marketplace/item/1649714958725398/
1987 Toyota Land Cruiser FJ60. 168000 original miles. $20k
  • Dobinson’s 2” lift (springs, shocks, Steering Damper, Anti inversion shackles, U-bolts, and Poly Bushings). New shocks 162463
  • ARB bumper with new marker lights from ABS
  • Warn 8274-50 Winch
  • H55 5 speed installed in 2012, somewhere between 104k and 158k
  • Older Hella Halogen off road lights
  • Duel Stainless steel battery trays
  • 98% rust free. No chassis rust. Minor body rust.
  • Southern truck. Mobile Alabama from 1987 to 2019. Ocean Springs Mississippi since 2019
  • No leaks on the driveway
  • Recent Compression (8/1/22) test is 160/150/146/160/135/145
Maintenance history
  • New OEM starter (166418)
  • New AC system (Denso Compressor, Denso Evaporator, Toyota Dehydrator, OEM expansion valve) 165443
  • New AC idle up vacuum switching valve
  • Toyota Kioto Headlight upgrade
  • Drum brake shoes replaced, all hardware replaced
  • Birfields done with new axle seals at 158540k
  • Fuel filter replaced 158572
  • Valves adjusted 160929
  • Transfer case cross connect oil line added
  • Fan clutch replaced 2017 by PO
  • Fan belts replaced 191294
  • Cap and rotor replaced 162032 with OEM waterproof
  • Air filter replaced
  • New spark plugs (165870) and spark plug wires.
  • Extended Diff breathers
  • All fluids recently changed (transmission (166002), transfer (166002), rear diff (166002) front diffs (160929), coolant, engine oil (166002)).
  • 4wd detent balls and springs replaced
  • Oil pan gasket replaced.
  • Roof gutters resealed
Spare parts included in the above price (can be deducted if buyer doesn’t want them)
  • Replacement hood
  • Replacement fender
  • Safari Snorkle
  • Mosely Motors Rebuilt alternator ($350)
  • Rebuilt carburetor by Mark’s Offroad in Burbank ($650)
  • Rear sliding windows imported from Australia, used ($500)
  • 2 new OEM windshield gaskets
  • Hood release cable
  • Clutch fork boot.
  • Front brake caliper rebuild kit (both calipers)
  • Random bin of goodies (distributor cap, large oil filters, other goodies I have acquired.)
I need to come see this thing. I live over in Covington.
There are all the rust spots on the truck. And undercarriage photos.
