Hi guys, looking for a bit of advice on a 1996 1FZ, uk spec so no OBD. I am experiencing high fuel consumption and have been looking at testing my oxygen sensor. The car has only one pre cat sensor. From the manual it says check at the diagnostics plug. My first question is the link it says to put between TE1 and E1, is this just a short, or is it something else. The manual refers to a part with a Toyota part number. I have measured the voltage between the signal wire and earth directly at the sensor and get switching between 0.2 and 0.8 volts which I think is out of spec, but I want to measure it at VF1 and E1 at the diagnostics plug.
Furthermore I have read that engine coolant sensors can be the problem. If this was the case, would the temperature gauge still work? (mine does). Also, how do I know that the fuelling system is operating in closed loop and not open loop?
Any help would be most appreciated.
Dave
Dave
