What just happened? Did I miss a joke?
O2 sensors wear out slowly, and can degrade performance and MPG long before they throw a CEL. On a former F150 I gained 3 MPG just by replacing O2 sensors at 80k. They are not cheap, through CDan they were around $150 each for my FJ80, with two required.
Do they effect fuel economy if in poor condition? If so, how can I diagnose them and how much do they cost to replace?
IIRC they are extremely inexpensive. Like a few bucks or something.
I replaced my muffler and soon after got a CEL code of P0130. Why would replacing the muffler cause the O2 sensor failure and will it happen again if I replace the sensor? Is there another root cause I need to be looking at?
I just wrapped up the front axle rebuild on my '94 and the motor is now running rough and the check engine moniker is coming and going. I've been tolerating a lower than normal idle for this truck, 600 rpm versus 700 (air off) and its just low enough to run rougher than normal. I realize the roughness may or may not be tied to the idle speed. Here's my question - if you guys are indicating that O2 replacement should happen every 60K, I've had them changed once in 245K miles, is it a foolhardy move to just go ahead and change them since I know I've gotten my money out of them? I haven't yet searched (this is my first thread on the topic) for how to check them and how to read the codes, and thought you guys might be able to point me to a hread like you did on the inner front axle seal. That single thread I was pointed to allowed me to go from a leaking seal and being broken down to fully repaired (did it myself). I am hoping to find a similar thread(s) on the low idle/check engine light issue. Any advice?
