o2 sensor bung extention
Pennsylvania
I've been searching everywhere for an available bung extension for the rear O2 sensor.. I just had a leak fixed that was between the cats, and still throwing 420 code... Before I replace the cats I'd like to gamble a bit more and get that rear sensor out of the stream... Any info from fellow mudders? Thanks ...
Did you check slee off-road. I thought I saw one on his website the other day.
unfortunately, those two are for screw in type sensors, the 96 uses a flange shape bung with (2) 8mm x 1.25 studs to fasten the sensor to the pipe
Im 95% sure you can unscrew that flange and use it as a normal one i did so on my 91.
This video fixed all my problems
not unless "this" just unscrews:
OP is looking for an extension, not a weld-on bung. That Slee one could be made to work, but the bottom (where it's radiused to sit flush on exhaust pipe) would have to be machined flat.
