- Joined
- Feb 27, 2004
- Threads
- 19
- Messages
- 371
Jman,
The generic rebuilt unit should contain the extension hose and 90 degree pipe elbow and instructions on how to hook it up. It's kind of a cheap workaround, but it should work. The problem I had was using OEM Toyota belts. I couldn't get the smog pump belt to tension enough, because the cardone smog pump hose elbow sticking out the side interfered with the powersteering gearbox, not allowing any more tensioning. If you have the same problem as I did, you could probably use a shorter belt to solve the problem.
I tried cutting, nothing I had would go through the hose, so eventually I took a huge screwdriver and pounded on the end that's not connected to the air pump to break the grip--it budged a few millimeters, and after that I was able to muscle it off.
