Just finished up pressing in the OME radius arm bushing that came in my 2.5 lift. Not too terrible, worst part was getting out the old bushings that were cemented in after 320k miles. The issue that I’m running into now is I’m a good inch or so off line to try and get the bolt holes to line up. Currently I have the front 2 in and can sort of use the arm as a lever and push it up and it rotates the axle a bit, but as you can see I’m pretty far off. When I took off the arms I had ratcheted up the axle but now when I went to install I noticed the straps were completely loose. I’m trying to figure out the geometry in my mind, but is there any sort of axle rotation method I can use to get these to line up?
