Non-adaquate Wipage
Doc
Utah
I'm not getting adaquate wiping control on my rear.
So I thought it was the wiper blade- so I bought a new blade. Didn't help.
The wiper blade only makes contact with the rear window for about 25% of it's travel, the rest it is apparently not being held tight enough to the rear window to make a difference.
Is the fix to buy a completely new wiper arm?
"I'm not getting adaquate wiping control on my rear. " ....... strengthen your arm and try a new kind of toilet paper :flipoff2:
Any chance it got bent somehow? I bent mine trying to unload some long lumber off of my Thule rack without any assistance. :doh: I had contact only on inside of blade (toward the pivot) but was able to simply bend the arm in toward the hatch and all is well. I think there is also a spring in there, maybe that weakens?
:cheers:
Happened to mine once. I just bent the arm a little -- all fixed.
Isn't the arm spring loaded? Maybe the spring is worn out and not pulling the arm to the glass as it should. I second the "bend it" fix. Or, borrow a spring from someone else's rear wiper arm.
I think the problem is that the spring is shot. I did try to bend it a bit, but it didn't help at all.
Just bought a new one from the Dan Man, as I needed parts for a tune up as well.
Damn rust!
Damn rust!
Wow! You can even order the little spring? I would have thought you had to get the whole arm or try and find one at the local hardware store to work. Now you have me thinking I need to add this to my next order from C-Dan, you know, just incase :D
P.S. Whats a smart shopper pay for a wiper arm spring?
Um, not the spring, the whole damn arm! $26.10 I think.... don't quote me.
I really need that thing for the winter, it never gets used any other time.
You need to keep spraying the arm with pen.oil or it will not spring back due to rust OR buy a new one.
It was too far gone for the lube trick, as I had already tried that. I will keep up the maintenance on the new one to avoid the problem re-occuring.
