I need some help identifying a noise my truck has started making. It is most noticible from the right side when coasting down at lower speeds. It is a metallic ticking sound -almost like a playing card in bicycle spokes (remember that). The speed of the "ticking" sound varies proportionately with vehicle speed. It doesn't seem to mke the noise when under throttle -not sure if this is just because I can't hear it over the engine /wind noise. for background, my truck is a 95 with 146,000 and does not have lockers. I recently had all four brake rotors/ pads replaced and new front calipers installed at a local shop. I've looked under the truck to check for foreign objects I might have picked up on the trail but it is clean under there. I'm getting nervous about this....could it be gear noise from diffs or Xfer case? Any help greatly appreciated.
TIA
TIA
