My 80 series dash warning lights suddenly stopped working it starts and runs everything else works any ideas where to start looking
Disconnected battery to test for battery drain pulled a few fuses to check themYou mean, other than the EWD? What was going on (driving -on road/off road- sitting tin the driveway, not running,etc), or happened recently before the failure?
1995I'd start with checking the fuses that you reinstalled to ensure that they are good. There is no single point of power for the dash warning lights; they all pretty much have their own circuits. So, if you've lost power to them all, you've got an open circuit somewhere. Go back over your work and retrace your steps.
What year is the truck?
Did you ended up finding the problem? My 1990 is doing the exact same thing. I just replace my cluster and everything was working fine, I’m not too sure if it’s because I keep taking the plugs out of the cluster many times but now my safety light is not working.1995
Will do thanks
