- Joined
- Nov 27, 2005
- Threads
- 1
- Messages
- 6
Recently bought my first Land Cruiser (FJ80 94)and starting reading the threads on things to upgrade. Love this forum! Fixing/upgrading the stereo and adding the CDL switch were the first things that made my list. I ordered the switch from Slee.
Today I put in the switch and did the pin 7 modification and starting routing some new speaker wire. As I was putting everything back together I noticed my headlights had turned on; this never happened before. I usually leave the light switch in the on position and let them turn automatically off when I open the door after running the rig. I manually switched them off. I then tried to start the engine. The engine turned over fine but not even a sputter; it has always started right up. Plerplexed I decided to search the forum for a possible cause before running the battery dead. Pulled out my FOB to lock it up and... nothing. It no longer worked, neither did its mate. Suspecting the alarm system I read some threads on it but found nothing that helped including turning the key on-off-on-off and pulling/re-inserting the connector to the box.
The fuses all appear good, the connectors are all snapped in; I'm at a loss.
Ideas anyone?
Ideas anyone?
. Pushed it back together and now my engine starts, the fobs work, the driver's door turns on the curtesy lights. One damn connector. Oh well, something learned. Thanks to those of you who attempted to point me in the right direction!
