Try using another key or replacing the batteries in the key fob as well.
How would this help (battery that is)?
To test your pump, you could pull off the engine side fuel line by the fuel filter, then turn on ignition accessory.
The key fob does not need a battery to start the truck. The battery is for the remote functions only. The RFID that allows the key to start the truck is passive on the key side and requires no battery. This is why we asked him if the security light was lit.
If the security light is off as OP says then the key has been authenticated by the ECU and should not be the problem.
