Due to the freebie tires, my plans for the build have definitely changed (possibly for the better).
Old plan:
Big tires
Lift
Steel bumper / winch
So without the largest tires, I do not currently see the need for a lift. My AHC is currently working fine and I ordered AHC fluid and plan on doing a flush in the next few weeks just to keep the system running as good as possible for as long as possible. If and when the system fails I will install a lift but with AHC in high I have more then enough ground clearance to offroad as long as I am smart about the path I choose.
Also with the AHC, I am slightly concerned about adding tremendous amounts of weight to the vehicle. I reached out to Dissent off road and ordered their aluminium front bumper witch only adds about 30 pounds over stock. They have a few cruisers that are sunning stock AHC with full aluminium front and rear bumpers so I should be fine. I will also be ordering a winch with synthetic line for safety and weight savings.
I am currently feeling really good about this unforeseen change in build plans. The LX is so incredibly comfortable and that is, in part, to it's amazing stock suspension. Because 90% of this trucks life will be spent on paved roads I am glad that this new plan does not really change its on road performance and comfort at all. Speedo is correct, super comfortable, and when I need additional clearance it is just a push of a button away.
Current plan:
255/75/R17 on Rock warriors with spacers
Dissent off - road aluminum front bumper
AHC flush
Smittybilt (98512) X2O Waterproof Synthetic Rope Winch - 12000 lb. Load Capacity
