NJ: 80 Series Subtank Parts (1FZFE) (1 Viewer)
NJ
  1. LX450
I am selling various subtank parts for the 80 series. Located in NJ and can ship any item or all of it. Will upload photos soon.
Sold - Dual Filler Neck for Petrol -> This neck has the factory blocking plate which is required by many states to pass inspection. Most sold are from a diesel and end up failing. This is an OEM part. Comes with gas door shroud but does have a small crack.
$250 - Fuel Transfer ECU - Needed to make system function using OEM components. I have 3 of these.
$75 - Sub Tank Switch (with possibly a pigtail if I find it)
$150 - Main tank pump assembly that has the transfer inlet pipe. This was not an option in N. America.
$150 - Main tank "75%" level switch. This is a required input for the ECU to stop the transfer when the main tank is roughly 75% full. A safety feature. I have 2 of these.
$150 - Overhead console (subtank and altimeter)
$125 - Overhead console wiring loom to kick panel. I have 2 of these.
$100 - main tank + transfer pump wiring harness. This will need a connector or two as they got damaged during storage.
$250 - Transfer pump assembly. This mounts under the body and transfers fuel from subtank to main tank.
Do you still have both wiring looms ? That go from Overhead console to kick panel?
I will grab better photos - this is what I had on my phone for now. First photo.
Bump on these items.
I just posted another dual filler neck for sale. Should have added it here.
Do you still have the above?
