prwillard2
$272, shipped with no tax following the 5% off coupon. My cruiser has 15000 miles on it, but not going to pass up a deal this good.
Just closing the loop here, after a few emails they "found" my order and i have received my UCAs now.I noticed the WELCOME5 code on my phone, but did not get it on the browser..probably popup blocker. A customer rep from DCI responded to my email, but just forwarded to Nitro, who was also already on the email chain. So we will see what comes of that.
Good deal. I may have missed this in a previous post, but has anyone confirmed that the little bracket is indeed for ahc sensor?Just closing the loop here, after a few emails they "found" my order and i have received my UCAs now.
You’ll need to weld on an ahc bracket. The one on there is for brake line.Good deal. I have missed this in a previous post, but has anyone confirmed that the little bracket is indeed for ahc sensor?
I haven't gotten an update on my order in over a week. Is there a good contact that you found that I should call or email? I just tried the info@ email address.Just closing the loop here, after a few emails they "found" my order and i have received my UCAs now.
I sent one email to both sales@dpioffroad.com and info@nitro-gear.comI haven't gotten an update on my order in over a week. Is there a good contact that you found that I should call or email? I just tried the info@ email address.
I suspect that adding the tab from your old control arm isn't a very large lift.Edit: I see now, the tab on the Nitro arm is on the section where the ball joint is closer to the rear bushing, where the AHC bracket is on the longer section towards the front bushing. The tab on the Nitro gear, is also parallel to the bushing through hole whereas the nitro tab is perpendicular. Maybe it's not difficult to transfer the tab from the OEM control arm over to the Nitro. Or maybe i'll be selling these along to some LC owner...
Thanks!difficult
I wasn't planning to run too much lift. Not more than 1-2" tops, I was mostly looking at it as a cheap maintenance item that also could get alignment back closer to spec. I realize it may cause more trouble than it's worth if overshooting.While these arms look great, curious if there's a functional reason you're looking for aftermarket UCAs? How much of a sensor lift are you shooting for?
These UCAs have built in caster "correction" so they are not exactly the same as OEM.It wouldn't cause any trouble. You can run aftermarket UCA's with zero lift or stock suspension components if you wish. Travel would still be limited by all other oem parts.
is this lot on the recall list?
