Results of UOA by Blackstone Labs:
Aluminum 2
Chromium 0
Iron 6
Copper 3
Lead 0
Tin 0
Molybdenum 56
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 88
Silicon 9
Sodium 6
Calcium 2787
Magnesium 21
Phosphorus 764
Zinc 908
Barium 0
SUS Viscosity at 210 deg. F 74.1
Flashpoint deg. F 395
Fuel % <0.5
Antifreeze % 0.0
Water % 0.0
Insolubles % .3
TBN 3.6
Miles on oil: 7980
Time on oil: 8 months
Milage at sample: 129,980
Filter: Toyota 20004
Crankcase capacity: 8 qts.
Oil added: 3 quarts
Usage is approximately 30% highway/70% city. This vehicle sees a great deal of short trips, plus extended idling, plus a couple of long trips. I do not baby the engine and use full throttle regularly when accelerating, passing, or climbing hills.
Here is a link to the last UOA with this oil with a 5400 mile interval.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=3;t=001262#000000
Blackstone's Comments:
You ran this oil about 2,500 miles more than the last sample, and the only wear increase we found were iron and copper, and they were slight increase. Your wear is still reading at or below the universal averages for this type of engine, which are based on routine oil use of 4,750 miles. This is a very good indication of normally wearing parts and careful operation. No antifreeze, fuel, or watter was found. TBN read 3.6, only slightly less than last time, and showing some additive remaining. With wear this good, we think you could run 9,000 miles for the next sample.
Bottom Line: This engine likes this oil and under normal driving should be able to push it out to 10,000 miles between changes with no trouble. TBN of 3.6 shows a lot of additive remaining, with the minimum that you want to see of 1.
Aluminum 2
Chromium 0
Iron 6
Copper 3
Lead 0
Tin 0
Molybdenum 56
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 88
Silicon 9
Sodium 6
Calcium 2787
Magnesium 21
Phosphorus 764
Zinc 908
Barium 0
Fuel % <0.5
Antifreeze % 0.0
Water % 0.0
Insolubles % .3
TBN 3.6
Miles on oil: 7980
Oil added: 3 quarts
