- Joined
- May 24, 2006
- Threads
- 6
- Messages
- 38
couple of questions:
1. What type of terrain do you drive on the most? Arizona has so much to offer - from high speed desert blastin' to hard core rock trails, to the wildly varied conditions in the high country - sand, gravel, hard pack clay, lava topped mesas, to bottomless mud and the occasional heavy snow.
2. Is the vehicle a dedicated trail rig, a daily driver that's used hard on weekends, or a commuter occasionaly used off highway?
For my type of wheelin' an A/T tire is not an option. I had a set of BFG A/T's years ago that gave me great tread life, but when I needed traction the most, they always fell a little short.
We live in Chino Valley, just north of Prescott, so the majority of our wheelin' gets done up in the high country. I own one of each of the above catagories: a '87 Toy rock rig, a '98 Taco used hard on weekends, and an '05 Taco that gets it's fair share of Forest Service road use.
In 2001 the rear spooled '87 trail beater started out with a set of 35" BFG M/T's. They were not up to the task - I got less than 8000 miles out of a set, and had major failures on sidewalls and tore entire lugs off the carcass. 3 of the 5 were warrenteed out. I bought a set of Goodyear MT/R's - they are an awesome rock tire - the first set went about 20,000 miles, so I'm now working on the second set. No failures - not one, zip, zero. They've been severely abused at Table Mesa and the Hammer's, and have logged thousands of miles of dirt time. If aired down to very low pressure (8 to 4 PSI) they work great in snow and mud.
For some strange reason I've not figured out, I bought another set of 31-10.5x15 BFG M/T's for the '98. Bad move...one I regret. Same problems as above - major tread chunking, prone to cutting. I though that they would be OK for moderate use, but I was wrong. I'll probably get a set of the new Cooper M/T next time...
The '05 wears a set of siped 265/75-16 MT/R's. The snow/ice traction is awesome, yet they also do very well on the easy stuff the Taco sees. Again, when aired down they perform well in all conditions. They currently have 16,000 miles on them and at the current rate of wear should get about 50,000 miles on'm before they need replacement.
Later
Later
