I plan to do the 2nd and 3rd row belts first so I can get it back on the road, then do the front seats on another weekend.
I did this 2x on the 80 so it wasn't hard, it was much more difficult the first time on the 80. Here's roughly what i did
1) Remove 3rd row and second row seats
2)Remove front seats - harder due to the wires underneath as well as the wiring for the headrest DVD players - finally found the wiring box underneath the seat and seats and removed the seat
3)removed the door sill on the rear
4)removed all the plastic inserts on the floor (they need a torx bit)
5)removed all the interior molding - most just pull gently. the rearmost sections also have a screw to remove and some of the seatbelts have to be detached to remove them.
6)removed the center console - some screws on outside and 2 in back behind cup holder. removed the center front of the console by lifting up
7)removed all the sheet metal in center console to be painted with por 15.
8)unbolted the components under the passenger seat to move so can clean all the way to the bottom
9)unbolted the components under the drivers seat to move so can clean - this is the fan. cannot completely move but can lift slightly to vaccuum under
10)used simple green and a brush to clean floor of the vehicle after carpet removed
11)took the carpet and used a spray carpet cleaner on the bad areas - let it sit. then used the pressure washer to apply a soap carpet cleaner. then pressure washed the carpet and hung to dry.
next plans to remove the seat belts and clean as well as clean the door panels - will like clean in place.
Be sure to pull the bottoms off the second row seats and clean out all the crud. Amazing how much crap accumulates in those hidden areas.
Nice looking truck, by the way!
