- Thread starter
- #21
Today I installed the engine mounts in the fj60. I had a friend help me weld them in as my beads are still a bit lacking. I drilled index marks in both mounts before cutting them out of the bj60 and then made a jig using some angle and the gas mounts I cut out of the FJ. I think I got the mounts within a mm or two of the proper location. I used por15 on the frame after the mounts were in.
Also have been working on the tcase rebuild, but before I can put it back together I am awaiting a 5th gear spline and sleeve as mine is damaged.
Has anyone adapted a 4spd cross member to work with the five speed? I am thinking that if possible, that might be easier than cutting off and reattaching the crossmember mounts.
Welding in the mounts. You can see the jig here.
Drivers side mount
Passenger Side mount
Drivers side mount
