It's more than you need, you will love this spec. Super smooth and quiet on our rough Denver streets. The pics I took don't do it justice...in person, car looks so balanced. After getting info from gaijn and Michelin direct, I'm now running them @ 33psi. They only require 29 psi cold (Michelin) to get load rating met. I may go 30 with a TPMS light removal mod (if its been done).
Would that be the same for BFG A/T KO2's 275/60/20? 30-32 psi
What would be the correct tire pressure for an LX 570 with BFG AT/KO2's 275/55/20? Thanks
Your 2015 LX570 came stock with P285/50R20 111V tires and a Recommended Cold Tire Inflation Pressure of 33psi F/R.
The BFGoodrich All-Terrain T/A KO2 LT275/55R20 115/112S Load Range D tires would have a Recommended Cold Tire Inflation Pressure of 46psi F/R to achieve the same Load Limit as the stock tires.
HTH
Damn, won't they ride like a rock? How low can you run them on a LX570 and they still be safe? Also if I am using the OEM spare for emergencies and have it inflated to 36 won't the tpms monitoring go off? With the BFG's inflated to 46?
Gaijin, I get it now, did some research.
Sorry, I was typing while you were posting this ...
All good.
now i too am concerned that I am running the wrong pressure on my new 285-65-18 Falcon wild peaks. I've been having trouble getting an accurate reading on the pressure, gauge says 40, tpms says 32. I was hoping to get them to 42 psi but now I'm not sure what the best number is.
When fitting LT-Metric tires to an originally P-Metric application, the Load Limit for the LT-Metric tires should be reduced by 10% (2,315 / 1.1 = 2,105 pounds/tire)
I'm questioning this assumption. I get that for truck that was originally fitted with LT, that fitting a P-Metric tire, would require a de-rating of said P tire, since it wasn't built with the heavier duty and higher center of gravity application in mind.
I'm not sure that it works the other way. Inherently an LT tire is built stronger than a P tire. So my intuition is that the LT tire needs no de-rating. And that 46 PSI hence is too high.
I of course defer to you as the expert. This just seemed off to me.
Thanks for entertaining my question and taking the time to school me (in a good way). Much appreciated.![]()
Always glad to be able to give a little back.You're very welcome!Always glad to be able to give a little back.
