Hello again,
Dismantling works always take less time than reassembling.
Finally she is back on the driveway.
you can see individual plates, this is shortcut from W Pogoni Za Szczesciem - means Pursuit of Happiness - it was the title of our RTW trip from 2010/2011.
You can see Fabryka4x4 bumpers, they are solid and fit quite well (need some works on the rear - but not a big deal).
Rear bumper is equiped in tire carrier and hi-lift hanger.
no plan for the winch right now, but there is a dedicated plate for it.
and there is set-up with beloved RTT from James Baroud
looking inside you can see new leather cover on driver seat, new leather on gear knob, and on the steering wheel
Small things but makes life more "luxurious" finally it is Premium Class SUV
Before first test drive after rebuild I did repack of front bearings
I used Terrain Tamer
Rear breaks needed much deeper service (over $200 in parts
) but finally hand break is working.
Break pads replaced with EBC Yellow Stuff - breaking power increase by 300%. Next upgrade will be replacing disc breaks with something from DBA.
You can see on first pic in this post big led bar on the roof rack - I had to change position of it - even with spot type of lens installed in it, there is too many reflex on the hood. So much better position for it is front bumper.
Second battery installed as well - with T-max steering panel
this is the set of buttons boys likes most:
and those
searching for best position for 220v outlets
and 1000W inverter in the central console (cd changer and sub removed)
here test of new lighting in the car:
daylights in the bumper (required in Europe)
and full power of light (high beam on):
