Is the floor supporting the tire as well? If you let it sit on the floor in addition to your hard mounts, you could decrease the stresses on the wheel well attachment points dramatically.
I agree putting something under the tire is a good idea, and I have done so already.
Not to rain on your parade, but that design won't work. The 3rd row seat bracket isn't shaped like that. It's basically vertical, which means you can't have the tubing cross it like that. (At least assuming the square on the bottom is the cargo floor.)
Looks way too complex as well, if you're gonna use the 3rd row bracket eliminate anything else going to the floor. If you want super stability, run a bar like I did up to the 3rd row seatbelt, or to the grab bar above it. If you do either of those, you can eliminate that huge hoop as well.
As with most disagreements, I think you are seeing things a bit differently than I am, which is fine. You had me paranoid for a second that I was missing somehing. My design would work just fine, but you are correct in that is would be more complicated than yours. I was just trying to come up with something that would provide the same amount of support as the slee design, without attaching to the upper points. I could draw another picture. This is a cool thread. I like seeing what different people come up with for the same issue.
I would disagree, 3 lug nuts is pretty easy to me...![]()
Well it's very possible I'm not just seeing it from the proper angle. That can be an issue with a flat line drawing with no perspective.![]()
I like it, I just don't like giving up cargo room.
I had an interior tire carrier about 10 years ago. Similar in style even. Tire lived about 4 months of it's life inside and all was well, it seemed happy. Went wheeling in a super muddy area and of course got a cut sidewall while in this disgusting, soupy, bad egg smelling, thick mud. Swapped out the tire and guess what? You guessed it, now I had a 35" stinky, muddy tire inside my truck for the next 8 hours. Interior tire carrier came out the next day. Only thing worse, was when it was on the roof, but that's a different thread....
Agree that removing the nuts isn't a big deal, bought the plates from Luke, etc. For me the bigger deal is getting to the nuts, then the tire needs to move over to clear the plate to come out. Most of the time when I would need the spare, I'm wheeling, so the cargo area is loaded, to make this happen, it would need to be unloaded.
So the design changed. We went with one where the spare rolls in from the back and is held by a strap, release the strap and it rolls straight out the back. It also holds the Puma compressor.
