GregRay
Old Member
That part number (23811-61032) is for a fuel pipe from a 1980 - FJ40 and is NLA new.
Hi all. I am working on a 74 FJ40 with the f motor. Someone put a weber on it and I want to put the Trollhole carb on it. From what I gather the stock spacer is missing and was wondering if someone has one. Also I am at 4500 feet and need to know what tuning on the carb I will have to do. We are gonna have to smog this thing when I am done.
Thanks
Thanks
Thanks
I know this has to have been covered before, just having a bit of trouble running it down. My old carb has 2 fuel lines running to carb. My new trollhole only has one. What gives?
Hey people I'm out of stock. Some reason I had a run on them last night. Will be about 10 days before I have the new shipment in.
Troll,
I need some advice on a carb issue. I've reached out to Jim C several times but have had no response realizing he's a busy guy.
I have desmogged my daily driver 4/1986 FJ60 2F; spaggetti lines, EGR piping removed and blocked off, ASV/ABV and hoses, air injection tubing; capped and plugged, deveined the air pump. Rebuilt carb, regasketed intake/exhaust manifold, exhaust manifold rings and springs.
The questions:
1. Does my distributor need recurving? I'm guessing not because it is vacuum advanced with electronic pickup.
2. Do you have a mechanical throttle desmogged carb that is pretuned for my application for less than a rebuilt/recurve from Jim that is available now? If so how much?
Thanks-Jake
Trollhole, I had a Jim C rebuild on my carby but having problems a year later and looking for a solution. There is someone selling these carbys in OZ, but wanted to look you up first since you're a good contributor.
I have a specific application that may be hard to fit. It's a 1981 FJ45 2F from OZ. it has a manual choke, however the primary choke return. Other than that vacuum there is only one other vacuum port and has some sort of rod linkage with cable accelerator. I can supply pics if needed.
Can you match it? How long of a wait?
Post a pic of the beast and I'll get you straight.
Hey Marshall,
Received new dizzy, plug & play, Now I've got carb problems, the fuel line into carb fitting is just like the one in the first pic of "show your new carb" its a drilled bolt with a "collar" fitting that swivels, problem is..female side stripped 1/2 way down, so threads don't catch, fuel leak..is this fixable? tried to get 90 deg threaded fuel fitting,but thread size is like nothing my guys have ever seen. If its a royal PITA..Then i'll order one of your carbs,and be done with it. Thanks M.S.Gould ( steve)
