New CSC member Brian (cactuscrzr)
Chandler, AZ
Please welcome new member Brian Van De Beuken (#cactuscrzr). Brian owns a slightly built 1997 FZJ 80 series and had also owned for 7 years but sold a 2006 Tundra double cab SR5 TRD.
Please tell us more about yourself, your vehicles and post some pictures of your rides.
Welcome to the club Brian
Slightly built :hillbilly:
Brian ended up with a sweet truck!
Welcome Brian! It was good to chat with you on the Mt. Ord run, hope you enjoy that Cruiser.
Thanks for having me, CSC.
1. 1997 FZJ80 Collector Edition (Picture from May ROTM at bottom)
2. Brian
3. Van De Cruiser (truck name)
4. 194,000
5. Mods (just a couple):
Front Suspension
  • Old man emu 850 J springs 3" lift
  • Slee Offroad front caster correction plates
  • Radflo 2.5" long travel remote res shocks 7/8 shafts
  • 2" drop bump stop pucks slee offroad
  • Iron man front adjustable heavy duty track bar
Rear Suspension
  • TJM 2.5" progressive rear springs
  • custom spring retainers
  • Iron Man adjustable heavy duty track bar
  • custom drop bump stop brackets 3.25"
  • custom rear shock mounts 1.50"
  • Icon shock skids
  • Metal Tech HD lower links with johnny joints
WHEELS and TIRES
  • 37x 1250 R 17 Cooper STT MT tires
  • Walker Evans Beadlooks 17x 8.5 3.75 bs (5)
Front Axle
  • Nitro Gear chromoly 30 spline front axle shaft kit
  • APR knuckle studs
  • full front axle rebuild at 178K wheel bearings , front brake, seals etc
  • ARB air locker
  • 488 gears with full bearings at 178K
  • Slee offroad AVM manual locking hub kit (part time 2wd kit)
  • Slee Offroad steel braided extended brake lines
  • Slee Offroad front sway bar drop brackets
  • TAC double CV front driveshaft
  • Marks 4WD abs sensor relocate kit (keeps ABS function when in 2wd)
Rear Axle
  • Nitro rear chromoly full float 30 spline axles shafts
  • ARB air locker
  • 488 gears
  • OEM rear brakes replaced 178K
  • Slee offroad rear steel braided brake line
  • Manafre rear brake proportion drop bracket
  • Rear drive shaft rebuild and tubed
Transfer Case
  • Marlin Crawler low range gears 3.116 to 1
  • Slee Offroad T case spool (part time kit )
Engine OEM parts restoration at 178K
FULLY built cylinder head and every seal replaced with OEM parts
new OEM radiator and all rubber hoses
full trans service at 190K
ARMOR
  • front bumper Slee Offroad short bus
  • rear bumper 4x4 labs high clearance
  • white knuckle off-road rock sliders
  • Iron pig center HD crossmember/ t case skid
  • sonoran steel spare tire carrier
  • smitty built H2O 8K syth winch
LIGHTS
  • rigid d2 duallys euro beams front
  • 16 led rock light pods under carriage
  • interior full led conversion
:cheers:
2. Brian
4. 194,000
Front Suspension
Rear Suspension
  • Icon shock skids
WHEELS and TIRES
Front Axle
  • APR knuckle studs
  • ARB air locker
Rear Axle
  • ARB air locker
  • 488 gears
Transfer Case
ARMOR
LIGHTS
1263805
May I add this to Who is Who page?
Welcome aboard... Nice looking cruiser!
