Nope, we didn't mate the GM gearbox yet, but the A440's going away.
We are doing a different take on the T/C adapter this time, but using the Toyota case behind the GM transmission.
one thing though, the 4l60E is rated for 6,000k and if this conversion took place on a more "built up" 80, would a 4l80E be a better choice? Not knowing a thing about transmission controls and all that, just a naive suggestion on my part I guess.
I've been doing some Google based reading on this, and the general view is that a 4L60E can be built to be fairly bulletproof behind modded V8's (there are companies who sell these) and the 4L80E has something like a 2.48:1 first gear, which you can forget in our application IMO.
The 4.2L weighs about 400 lbs, so you are losing some 300-400 lbs of engine weight (I have Googled and searched here and cannot find a weight for the 1ZFE so am going off of "IIRC" figures that have been mentioned over time), and the transmission is about 135 lbs and I imagine some bit lighter than the A343F, so for my rig this is about a 7%-8% total weight reduction and would keep me well under 6K, and I tow very rarely. Overbuilding costs weight, and weight is the enemy of sticking with any I6 platform over a V8 (not sure what to do about those four growing kids).
I don't know what it would take to mate this engine to the stock tranny, but the gearing improvements of the 4L60E make a compelling reason to stick with the transmission used with the engine, particularly given long term parts availability by moving to a GM platform.
In some reading on GM boards, there is admission that this engine is more refined under throttle than the available V8 platforms (5.3/6.0). It just seems ideal for an 80 that will be kept on a moderate diet for weight control (if you love the inline six platform).The 4.2L also has a turbo aftermarket, although that is of no interest to me
I wish I could do this kind of swap - I am getting pretty committed when funds are hopefully available next spring, but I am at the mercy of somebody who can actually do the work without it becoming a $10K project.
I was just doing some simple math to look at fuel savings:
- my annual mileage usage has grown to 10K. I get 12 mpg on average mixed highway/city.
- 20 mpg mixed seems conservative on the Blazer/Envoy boards.
- @ $3/gal, I spend $2,500 a year on fuel for 10K miles
- @ 20 mpg, that would drop to $1,500, saving a $1K/year.
- I have 37's, so 18 mpg seems more realistic, but across the board a 50% fuel economy improvement seem conservatively realistic, so that's $833 annual savings. Even if you go more conservative you are looking at $750 pretty easily.
Assuming $2,500 total in parts, that is paid back in under 4 years, labor is the x factor. But even somewhere around an 8 year payback given the greatly increased enjoyment of the rig and the fact that the payback will increase if fuel costs rise significantly means I would have a good hedge to protect the long term investment. The payback period also shortens if I need to drive my 80 more (I don't commute except once a week as it stands now).
The figures are pretty compelling when you choose a low cost platform that can be had at those costs for a low mileage starting point. This also doesn't factor in selling a 1ZFE with headgasket PM replaced by Slee plus A343F in perfect working condition, both with under 150K miles, assuming a buyer in the market.
is there another thread that goes with this...where are the pics?
We're just getting the last of the (small) parts together this week. We did my mountain truck FJ80 last year with the same engine family, but an I-5. That truck turned out pretty well.
Pics of the (242HP) I-5 swap are here:
Picasa Web Albums - TL Care
I'll post pics of the I-6 as it comes together...
TT
TT
It's a good question-- I've got a couple of rigs with 4L80s in them, one's a Silverado HD and the other a long-wheelbase 1T Express Van (which is a surprisingly good tow vehicle, oddly, with the long wheelbase and forward seating position-- even with the stiff rear suspension-- have towed amazing loads with what looks like a family van.). The 4L80 is considered virtually indestructible, but the ratios and the fuel economy are both a big turn-off. It can be configured to connect via a transfer case for 4WD. But, even for a built FJ80 it seems like overkill. That 2.48 in First is a killer and, at least in my Silverado, it's Overdrive ain't Over enough-- I'll turn 2500 RPMs on the freeway, when it could be pulling the truck empty at 1800, so the mileage suffers. 4L80 internals are very rugged, so it also chews a lot of HP at speed too.
The 4L60 is very rugged in stock configuration, but can be built to be very strong. The 4L60 is upgraded to 4L70 for use in the Trailblazer SS-- behind an LS2 it's holding 400HP/TQ and, in turbo'd trucks, a lot more with no internal work. So, if I was building a really heavy-duty FJ80 I'd still opt for the 4L60, but probably look for the TrailBlazer SS version (same external dimensions and fit) and never worry about it.
I hope this goes well for you. I htink it is an excellent alternative to the GM v8 swaps. We just finished a 2007 5.3 swap into a 71 fj40 and the fittment of everything was a pain in the butt. I'll be keeping tabs on this swap as it has peaked my interest away from some of the diesel options I'm looking at.
I hope you can find away to make the stock fuel system workable for the 4.2.
As a side note, I took a quick look locally and found a 2006 4.2 with 42k miles for $700. That price might have included accessories and wiring as well. If it did include everything, that is an excellent deal, IMO.
Excellent info, thanks for typing all that in.
If I can keep my York, this swap would be the cat's meow!!
This may have been posted but what is the torque number for this engine? I see the 275 hp. With a proper tune, could these numbers be pumped up? I assume so given the aftermarket support for the GM engines.
Thanks again. Looking forward to your progress.
edit: the torque is the same as the 1FZFE, read it earlier in the thread. So, perhaps some aftermarket goodies can bump that up, I hope! I wish my 1FZFE engine had a wee bit more torque, perhaps another 75 ft-lbs.
I'd love to see a list of the "small" parts once you are ready to go, if you're willing to share the secrets
I noted in your I-5 build the purchase of GM tuner software. That's where I start to get scared about finding the specific local knowledge to do this right...
300K + on my 3FE now. Subscribing as I see this in my future.
Any idea if it would slip as easily into a FJ62 ?
