- Thread starter
- #101
Well that was easy, I think the PB helped....Time to order some new dielectric grease and a set of wires.
Automotivetuchup.comI am once again asking for your help. I got a can of "exact match" duplicolor knowing that there may be some color variation but not caring a ton as long as it was close because the spots I'm touching up are relatively small. Well, it's GREEN rather than the original color. I searched for 6M1 color code, which I believe is the correct one for my truck but this stuff is laughably off. Going to sand this back down and reprime (which is okay because I didn't blend it well and there's a ridge anyway) My question for you guys is - Is there a place where I can get a decent can of aerosol touch up? I have some spraying equipment too, but since what I've got to paint is probably less than 2sqft total, I'd rather just go with the simplicity of a rattle can.
I have used it and it’s very close plus the have the clear coat
Thanks boys. Turns out that the NAPA 3 miles from here does the same. I'll give em a call today and get a can made up. Shoulda just spent the extra $7 and done that before and saved myself repreppeing. Glad I know about it nowWhat @Broski said. I also went to Napa here and they have a perfect match paint mixing service. I had a few aerosol cans made and it was without a doubt legit.
No kidding? I've watched some tutorials and stuff in the past and always had to wetsand the ridge down no matter how careful I was. Absolutely will try this.with the side towards where your painting rolled up like a wall.
Twas my first time ever painting an entire vehicle and there was so much orange peel that Tropicana threatened to sue.Ha ha I use the clear and skip all that wetsanding & buffing stuff with really good results.
Thanks for the heads up, never would have found that store otherwise. Ordered a few wheel bearings and a knuckle rebuild kit today....my drivers side axle seal is leaking pretty good and the diff was so low before I didn't notice until I swapped the fluid. Truck has 203,000 miles on it and I don't hear a loud clicking on the CV's when it's up in the air......should I just put new ones on? If not, is there an easy way to repack them?I like and use Cruiser outfitters (Kurt @cruiseroutfit) you can get a complete axle rebuild kit from them.
Quality parts, excellent staff and service and super fast shipping.
If some of the others vendor on this site ran there business like Kurt does we wouldn't see the complaints that we do!! Just Sayin
You can swap them from side to sideThanks for the heads up, never would have found that store otherwise. Ordered a few wheel bearings and a knuckle rebuild kit today....my drivers side axle seal is leaking pretty good and the diff was so low before I didn't notice until I swapped the fluid. Truck has 203,000 miles on it and I don't hear a loud clicking on the CV's when it's up in the air......should I just put new ones on? If not, is there an easy way to repack them?
Repacking the ( CV ) birfield is easy just need gloves, it getting them clean is the hard part.Thanks for the heads up, never would have found that store otherwise. Ordered a few wheel bearings and a knuckle rebuild kit today....my drivers side axle seal is leaking pretty good and the diff was so low before I didn't notice until I swapped the fluid. Truck has 203,000 miles on it and I don't hear a loud clicking on the CV's when it's up in the air......should I just put new ones on? If not, is there an easy way to repack them?
Figured it was relatively easy. I've never taken one apart or put it back together, and the youtube I watched showed a guy putting them in a stack of 5 tires and smashing it down. I don't have 5 wayward tires around.....what do you guy(s) do to get them loose? Also, I'm afraid my power washer will spray grease everywhere so my plan is to sneak them into the "you spray here" car wash after dousing them in degreaser and just blasting them there. I don't know how I'll be able to avoid the grease spatter cleaning out the actual axel, so I'll have to just live with that, but for $3.00 in quarters Im okay relocating the pieces I can actually move. I'm telling you guys, I keep harping on my wife to move to a spot that I can have a 40/40 pole barn and a lift so I don't grease the house up but it's a tough sell.Repacking the ( CV ) birfield is easy just need gloves, it getting them clean is the hard part.
Most people put them in a 5 gallon bucket with diesel fuel in it and let them soak
This is a easy way but a peace of schedule 40 PVC longer then the axle well work, Pick them up together and slam them on the block of would.
JMHO you don't want water in the birfield once you have them separated, soak them in a bucket of diesel. you just need enough to cover the birfield maybe a gallon or so.
Also have the new lock rings on hand in case they break
