GTSSportCoupe
2LTE abuser
My pedal has been spongy and some days are worse than others. My calipers and brake lines are all in really good shape. But I did replace some flexible lines a while back, and have just not been able to bleed the spongy out no matter how much I try.
So, today, giving it another try, I notice huge 1/2" bubbles coming up in the reservoir as my son is pumping the pedal. Is it pretty safe to assume I have a worn out master cylinder and air is somehow being drawn in? There is no external brake fluid leaking visible anywhere around the master or inside the truck.
So, assuming it is a leaking master cylinder issue: the sub assembly is no longer available. Seems the best I can do is a 'cylinder kit'. Any of you bought one of these and done a DIY rebuild? Success?
