My71FJ40
I found my exact problem and am reposting the conversation to see if FJ40Jim is correct...I hope so
rocman1
I got my fuel pump off and cleaned the area up. Got my new kyosan pump from JT off road and went to put it on. The directions told me to make sure that I put the spacer back in between the block and the pump or else it could destroy my pump and or my crank. The problem is that my old pump did not have a spacer when I took it off. Only a little gasket material and an old gasket. Do I need to make sure that I get a spacer before I try to crank it up. I already replaced the pump on the engine but have not tried to start it or anything. I was waiting to hear back from some of you all before I did something stupid. Please help me out with this issue. Thanks, RG
shelfboy1
if you dont use the spacer it will break the arm off good luck
FJ40 Jim
The spacer is used with the 1979-newer pumps. The 79-newer pumps are distinguished by having 3 push on hose connections, and ar crimped together (non-rebuildable). The 1978-earlier pump does not mount with a spacer, unless it is going onto a much later engine block.
Well, anybody got anything different? Also here is a pic of my two fuel pumps side by side...the New Kyosan has a bit longer arm on it...and I hope that won't be a problem. The one I took off was a Nikki...?
Thanks, Luke
rocman1
shelfboy1
FJ40 Jim
Thanks, Luke
