We're looking at buying a home in Eagle, ID. It was built in 1992. The inspection report identifies two things that I am concerned with, everything else is minor and easily mitigated. The HVAC system is a split system.
1) the electric central AC unit's estimated age is 10-15 years and the Goodman (mfg) design life is 7-10 years. "The cooling system is beyond normal life expectancy. Anticipate repair or replacement needs."
2) The Goodman natural gas high efficiency heating unit's est age is 10-15 years and it's design life is 10-15 years. "No elevated CO levels were noted at random registers through the home. The unit was operating normally at the time of inspection, but is rated fair for age. Repair or replacement should be anticipated.Due to age, it is recommended the unit be serviced and evaluated by a qualified HVAC contractor prior to closing as a precaution."
So my questions are:
1) Since these are separate units (the AC is outside, the heat unit is in the laundry room), is it possible or wise to consider installing a high end heat pump to do the work of both?
2) What's the best, most efficient, HVAC home system available nowadays?
3) What should I expect the installed cost to be?
