I have installed. In terms of mounting it was straightforward - I had to trim a couple tabs on the headlight brackets but after that my factory grill fit perfectly. You will need the corner lights for the quad setup.Hi Douglas,
I have quad lights on the way and I'm looking to install JW Speakers as well so I'm looking for tips. I was wondering if you've installed them, and what all was needed in terms of adapters/modification?
Thanks
Wiring will need to be modified, Toyota switches the ground side which complicates things slightly. Mine are set up like this - Instructions for LED Headlight upgrade - https://forum.ih8mud.com/threads/instructions-for-led-headlight-upgrade.1006581/#post-11299018
Basically a dedicated ground for the low beam and the Toyota switched ground controls the high beam. Works well, all 4 lights are on when high beam is on - only downside is no high beam indicator. There is a fix for that but I haven’t looked into it.
